I've read a few threads on here regarding protecting the paint when you put the hardtop on...and using mylar tape, the original ford tape, open cell weatherstripping, or the QAA stainless steel (which I tried to put on, but didn't do a great job so it may have to come off in the Spring...hopefully 3M adhesive comes off)). In those threads people said to use Ford's Silicone Lubricant or Ford silicone grease on the weatherstripping, yet the Ford manual does not say this. it does say:
"Using a mild detergent, clean the weather-strips on the top before installing it on the vehicle."
and
"Once per year, apply a small amount of silicone lubricant, F5AZ–19553–AA, to the receivers as shown. The lubricant should be sprayed directly into the hole to avoid contaminating the trim parts."
So I am confused on what to do, considering I have no silicone spray or grease. I do have some lithium grease, but that would be for metal on metal.
1) Since the Ford part number mentioned in the manual for Silicone Spray isn't available, and Silicone Sprays are mostly the same (???), can I just get any old silicone lubricating spray at the hardware store or from Amazon to spray into the receivers?
2) Should I also apply some sort of silicone lubricant to the weather seal that rings around the back of the hardtop? What about the front?
3) If #2 is a go, the same spray stuff for #1, or do I need a silicone grease instead?
and
