My ' 03 with 25,000 miles was brought into local Ford dealer for I thought to have the coolant drained and replaced. To my surprise they wouldn't do it. They told me to drain the coolant hoses have to be removed and since the part where the hoses are connected are made of plastic have a tendency to be brittle and break. I should mention that this is in south Florida. Ok so now what do I do? Are they correct?
Coolant change
Hello Larry, My greatest disappointment with my '02 is parts availability. When I got the '02 last year the cruise control cable was busted. I went to my local Ford Dealer for it and other parts and the parts manager laughed. He said E-Bay is your parts supplier now. It is hit or miss. Forum members will tell you about their trips with no issues. That's great. We just drove from NY to Florida, but not with the TBird. I drive it close to home. I also steer clear of the dealer for service I cannot do myself. I believe the plastic parts you mentioned ARE available on E-Bay. Good Luck --- Alan
Originally posted by larry n View PostMy ' 03 with 25,000 miles was brought into local Ford dealer for I thought to have the coolant drained and replaced. To my surprise they wouldn't do it. They told me to drain the coolant hoses have to be removed and since the part where the hoses are connected are made of plastic have a tendency to be brittle and break. I should mention that this is in south Florida. Ok so now what do I do? Are they correct?They are Here. Scotty, beam me up!IT'S 5 O'CLOCK SOMEWHEREVisit the TBN Store
Originally posted by Gobird View Post
Larry, I'm in south central Fla. in Sebring. Had my dealer do this and I believe they used air pressure to flush the system. Their located in Avon Park and the dealership is Bill Jarrett Ford.They are Here. Scotty, beam me up!IT'S 5 O'CLOCK SOMEWHEREVisit the TBN Store
Originally posted by Lakebum View Post
Greg, Where did you find replacement coolant parts for the ones that came from the factory that were plastic?
Richard & Gordon
Had the oil changed at the dealer Thursday and asked them to check the anti-freeze because it is 15 years old and has probably lost its anti-corrosion properties. They reported it was fine, it's good to 32 below, and doesn't need to be changed.
The car has 24,000 miles on it...
Quickdraw
Raccoon Lodge Administrator
Originally posted by Quickdraw View PostHad the oil changed at the dealer Thursday and asked them to check the anti-freeze because it is 15 years old and has probably lost its anti-corrosion properties. They reported it was fine, it's good to 32 below, and doesn't need to be changed.
Regards,
Mike Grimm
Originally posted by Grimmo View Post
Harry, I have the same concern and year/mileage situation. But isn’t there more to the overall quality of the antifreeze than just the freeze point?
