Well... this is a strange one. On my 05, the heater control on the drivers side controls the heat on the passenger side vents, and vice versa. I have tried to find a pictorial in the forums on what is involved in pulling the heater control panel without breaking things, and other unpleasantries. I would guess that by simply reversing the wiring plugs to the rocker switches from one side to the other, this issue would be solved. But I don't know quite how to proceed with accessing the area in question. I have only had the car for 5 days now... but I have done enough car repair to know that if you know the tricks, any job is much easier. Any help would be greatly appreciated.
Heater controls.
How can you tell this is happening?02 Nieman Marcus-SS htp-f/sil. #165 - 21 states-DC
The hot and cold controls both work on opposite sides. Turn up the drivers side heat, the passenger side gets hot. Turn it down, it cools. And vice versa. They both independently work as they should. The dual control is not on. I do have the owners manual. I will check the other functions to see if they are also reversed... Stay tuned.
I know I sound like a broken record but it could be that darn Dual Heater control valve. It is a Jaguar design and when the valves stick you get all kinds of weird temperatures. Another thought occurred to me, you say you have only owned the car for a short time. Perhaps the valve I refer to was replaced backwards. If the installer was unfamilar with Tbirds it could happen.sigpic
OK, it is set on dual... Temp L & R set at 60 deg. Turn the drivers side up to 90 deg. The passenger side gets hot. Turn it down, it cools. Turn the passenger side from 60 deg to 90deg. The drivers side gets hot and cools when turned down. All the other functions, blower settings & fan, work as they should. I begin to think this car came from Australia or something... :-/ I don't think the gang plugs in the back of the panel are interchangeable. There are two gang plugs that would handle several functions judging by the amount of wires involved, and changing their position if it could even be done, would then mess up the other functions. Any ideas??
Calvin, that makes sense. I don't know how that plumbing should look, but I think I know where the valve is. Passenger side on the radiator, under the large radiator hose? It looks like two 'solenoids'(?) side by side, with three hoses? If I understand, you are suggesting that the hoses on the Dual Heater control valve that go to the heater core(s), are reversed? This makes perfect sense to me. Any other ideas? or do we have it figured out.
Originally posted by Mujiir View PostAny ideas??21 years, 174K miles, 48 States X 2 & DC, 9 Canadian provinces, 8 European countries, 3 Caribbean Islands, 3 Hawaiian Islands, 100+ National Park locations, 150+ T-bird events, 190+ retrobird diecasts/models, 13 TOTM pics & some very special friends...THANKS TBN !
If you eliminate/turn off the dual feature, what happens when you adjust the left up/down feature? As a rule it should control both sides.02 Nieman Marcus-SS htp-f/sil. #165 - 21 states-DC
Originally posted by steelblue5505 View PostI'll put my money on the wiring at the dual control valve not the hoses. It would be a very simple matter to switch them, there is a pair for each solnoid. If the switch makes no difference, then switch them back & go after the hoses being mixed up
Thanks to all for great help and suggestions. I will look into the wiring at the valves, then look at the placement of the hoses. Stuff like this makes me nuts when you have something you think is really nice... except for that one little thing. I surely could just remember it works backwards, and no one would ever know... but me. And therein lays the rub. I will report back on my solution. You all rock! Thanks again. :-D
