In my conversations with Earl (007161947), he suggested to me to take a closer look at the soft top. Susie and I took her out for a drive, and Earl's onto something. That which MAY be the normal twisting of this convertible body is simply revealing a soft top that is "responding" more to this twisting than either of my 2 prior Birds (my prior IG was silent - no noises at all). These noises appear to be NOT coming from the top's hardware, but rather squeaking noises made by the soft material. Not sure I'm making this clear or not...
Vertical X-Brace behind Passenger Compartment
Originally posted by AZTB View PostUPDATE: I decided to loosen all 14 bolts to the main x-brace under the passenger compartment, and the 4 rear bolts to the x-brace under the engine. My reason for doing this was simple: with the flex noise I was getting from the car, I began to wonder if the 2 horizontal braces under the car might have been tightened when the car wasn't flat (all the work done on the car by the prior lady was done at the dealership, but I have been in this long enough to know that Ford dealerships don't always know this car). I felt I needed to be sure these bolts were "tight" when the car was flat...or at its "zero" position for tightening these bolts.
So I put the car on a flat surface (garage) and loosened all 18 of these bolts - I pulled the car out of the garage onto the street, and then backed it back into the garage (allowing the braces to "realign" to a flat position). I then tightened all 18 of these bolts to specs. I then pulled the car out and drove it around the block, turning in both directions, listening for flex noises.
The noise seemed to be significantly diminished - so I'm going to watch it for a while and see if it's really better. I will be putting the hardtop on here in the next few weeks as our night-time temps start climbing into the high 80's/low 90's. Then I'll check it again. If it gets noisy again, I'm taking it in to have rear suspension looked at and also get a 4-wheel alignment per Brad's suggestion.
If anyone has any more thoughts/suggestions, I'm always open to this site's expertise.
Thanks.
All 13mm. Loosened all first, then torqued (after shakedown cruise) to 45fp. No lift required.
Factory lock-tight was definitely evident.
HermannLast edited by HKS; Oct 9, 2019, 08:54 AM.2002 TB Motor Trend COTY Blue/White/Full #24737 (One of 291)
Some improvement. Need to do the front OF THE FRONT X brace.
that may require raising the car somewhat.
I do everything piecemeal.
Originally posted by Frank Dreano View PostI had to pop loose a plastic splash shield to get to all the front "X" brace bolts and did also have to raise the car slightly....its just too low to work a torque wrench under there easily..2002 TB Motor Trend COTY Blue/White/Full #24737 (One of 291)
HKS, please read your post on "cowl Shake" from two months ago. 46fp is the torque spec for the cross brace bolts.
Originally posted by 5bird7 View PostHKS, please read your post on "cowl Shake" from two months ago. 46fp is the torque spec for the cross brace bolts.
Hermann2002 TB Motor Trend COTY Blue/White/Full #24737 (One of 291)
Finally drove the Tbird over the 4 blocks of bad road again, same road that made me decide to check the X braces.
The potholes on that section of road were spaced just right, setting up a shaking rattle/oscillation.
Each pothole added energy to the earlier one resulting in in extreme shaking.
Well, I have to report a significant (worthwhile) improvement due to resetting the X brace torque.
There was a rumble caused by the tires, but the body rattling noises were insignificant.
I think it had a lot to do with letting the hardtop decide where the X braces like to be centered. So, in my case, doing the X brace re-tightening with hart top on was correct.
See post #18 also.
HKSLast edited by HKS; Oct 14, 2019, 04:50 AM.2002 TB Motor Trend COTY Blue/White/Full #24737 (One of 291)
