Fuse box plastic cover
  • Fuse box plastic cover
    First thank you all for your replies, And the opportunely to join a great forum. I am having trouble removing the plastic cover right passenger 2002 fuse box, how does it come out?
    2002 Ford Thunderbird
    White on White
    Black Interior
    Factory Chrome Wheels
    All 3 fuse boxes -- one in the trunk, one in the kick panel,& one under the hood -- are on the passenger side. I'll assume you're looking at the one under the hood. Okay, on the front of the fuse box is a latch. Push in on it, meaning push it towards the rear of the car. Then you should be able to lift the lid. Lemme know if this works for you. This info is based on my 2004 'Bird, so let's hope it applies to your '02. ---Will
      If its the passenger footwell fuse box, one of those thin plastic interior trim tools will do the trick. I think there is a slot you can put the tool in and lever the cover off...
