2002 Thunderbird Not Starting - Fuel Pump "clicks" but not running
  • 2002 Thunderbird Not Starting - Fuel Pump "clicks" but not running
    My daughter backed the car out of the garage, started running rough, then died. Would not restart. Will turn over but won't fire.
    When I turn the key I can hear what sounds like the fuel pump clicking from behind the seats, but not the familiar "whirrrr" of fuel pump. (Note, I think this is the version that still had the one pump). So my guess is it is getting power but the pump may be done. Pretty good basic skills, but watched a couple of videos and not interested in ripping apart the whole back of the car so will take to proper mechanic.
    Before I do, just wanted to check with the community of anything else I should check. Here are assumptions so appreciate you telling me if wrong as I can then check.
    * Fuse: Pump would not click over if the fuse was blown.
    * One Pump: Since only hearing one click, could there be a second pump and that fuse is blow? Series Parallel? Does is matter.
    * Fuel Filter: Possible, but seems that would have cause more gradual issue that just stopping.
    I did check the filler cap and don't smell any fuel, etc. in engine compartment.
    Thanks again for the help. Wife loves her bird and would like to get back on the road in the best weather time period for us.
    Bob
    All 02 to 05's had two pumps. Probably one of the pumps. I have an 02 and had to replace one of the pumps.
      Bob
      The only pump that would make a noise is the one with the electric motor, on the passenger side.
      The drivers side pump has no electrical connection other than the fuel gauge float (no fuse).
        How does it pump with no power?
          The drivers side pump is a jet pump. No moving parts. I takes a stream of fuel from the passenger side pump to operate the jet pump.
          Something to do with the Bernoulli principle, I think.
          It is the transfer pump to the passenger side tank where the electric pump is located.
          Saddle tanks need this. Just pretend the driveshaft is a horse and you hang your saddle bags on it.
            Thanks, definitely behind passenger side and great info on how the other pump works. Looks like busted pump.
