Thunderbird Car alarm
  • Thunderbird Car alarm
    Does anyone know if it’s possible to disconnect the car alarm on our birds?
    i dont have a remote and only one key so its a lottery every time i open the door if it’s going to honk (i never lock the car but i often disconnect the battery because i have problem with drained battery)
    somehow get a remote. although keys are a pain to have programmed remotes are easily programmed by yourself
      Yup, tow matching remotes fobs are about seven dollars on eBay.
        If I'm not mistaken, any time you lock the car the alarm system is operating. Since I keep my car in a locked garage, I don't lock the car and turn on the alarm system. That could be what is draining Fredrik's battery. Am I wrong?
          Pretty sure that you you are correct.
            https://www.thunderbirdnest.com/foru...blem-revisited
              Yes but what i understand is that i must have one working remote to be able to program one more or is it the key that works like that
                So if i just close the door it drains battery?
                but if i close the door and just activate alarm without locking the car it dont drain the battery?
                (I have no remote programmed for my car but i have bougt one from ebay)
                  Thank you i read it and i understand that my car should not drain the battery because i never lock it and never use the alarm, but if i brake the power and turn on the power (got a main switch in trunk) then the alarm goes off when i open a door if keys are not in ignition possition
                    I think that the technical term for your car, Fredric, is that it's haunted!
                      you do not need a working remote to program a new one. the Key is a different matter
                        The remote fob programming procedure is in the owner's manual and fobs are under $8 on Amazon.
                        You can even get various colors, my new ones are red to match the car's paint and to stand out among all the fobs on the shelf by the garage door.
                          i think so too is there any one on the forum that has had a hounted car before me so i can serch how to get rid of the problem? hihihihihi
                            nice thank you
                            then i shal program my remote
                              thats smart its always a problem to get right keys
                              and thank you for the tips i will look in the manual how to do it
