My 04 turn signals are blinking very fast.Does this indicate à blown bulb?
Fast Blinking Turn Signals
Here's an idea .... turn the right signal on and walk around the car. If the bulbs work then try the left side. That way you can narrow down the problem.Unbelivable TBN trips including ALL of the lower 48 States plus 9Canadian Provinces, 8 European Countries, 3 Caribbean Countries, Countless National Parks and have attended well over 100 TBN Events since 2001 and counting. Best of all ... fabulous friends.
My top willl not go down; did see some fluid on garage floor last season (seasonal resident in Bradenton,FL where Bird is garaged). So… we’re thinking pistons just need some fluid? Anybody in our area have a resource as we did check w/a few garages and they could not help! Appreciate your help… TU.
Birdee
Originally posted by DavidA View PostHere's an idea .... turn the right signal on and walk around the car. If the bulbs work then try the left side. That way you can narrow down the problem.Quickdraw
Raccoon Lodge Administrator
Originally posted by Vintage Merlot View PostDoes it seem likely that both rear blinkers would fail at the same time. Front work
rears don't
