hello folks, this has been a long saga but back to trying to resolve the coolant leaking problem once again and for all I hope.
Ive had the thermostat housing/assembly replaced 3 times, (OEM parts only) by a couple of local friendly shops, each time the problem seems to go away and return.
Ive made sure the correct burping etc has been done as many have pointed out that can been an issue.
Recently I have a suspicion that maybe the coolant reservoir having a tiny leak/crack may be the issue , given the tell tale puddle forms usually just under where it it located, it seems that its a fairly common issue when I did some research on line. Does anyone have any experience with the coolant reservoir/or its associated plumbing leaking? I understand the OEM part comes with the tubes already attached/glued but runs about $300 vs the $60 for a non OEM part online, seems like its worth the investment.
thanks all
Smed. 2005 TB is 20 years old this year! I still love it.
thanks all
