Headlamps
  • Headlamps
    I need to replace my headlamps but want input on options. I want brighter light than the standard halogen lights.
    I had tried LED headlights, Steve, and while it was truly a plug and play install, I think it's best said that I very shortly went back to freshly cleaned headlights, and Silverstar Ultras.
    Good luck, and let us know what you decide upon.
      Thanks for the reply. Have you replaced your light or just cleaned the lense surface?
        Lens not lense
          I cleaned the clear front covers, Steve, although the ideal thing would be new ones. If your headlight covers are cloudy, it can definitely improve things a bit; if it's helpful, the cleaner I used was by Sylvania. For the brief time I had the LEDs in, the difference was remarkable, but they were ultimately unreliable, not lasting very long. Our cars are a product of their time, the reflectors were designed for the older style bulbs, so if you try the LEDs, be careful to aim them so they don't blind oncoming traffic. Perhaps a more recent LED set might work better, YMMV.
            I put in LEDs and they made a huge difference. As stated above, you will need to lower the beam a lot.
              I replaced both of my headlight units for less than $150 installed. Can't remember what bulbs came installed in the units but they were next generation of some kind not LED. Did this about 2 years ago.
                I replaced the halogen bulbs with Sylvania 9007 led, easy just followed the instructions and didn't have to align the headlights.
                https://www.walmart.com/ip/532313752...2-dc3f4fd4e84b
