Door Ajar, No power locks, jumpy on hills
  • Door Ajar, No power locks, jumpy on hills
    Could this be a computer problem? The door ajar started about 6 mo ago, the locks sometimes will not work with the remote or the door panel switch, now my wife reports the engine jumps and hesitates on uphills. 2002 T Bird Blue, 54000 miles. Any ideas?
    Re: Door Ajar, No power locks, jumpy on hills
    Try this solution first - unhook the battery and let it sit for a least 15 minutes - to give the computer a chance to reset. Then hook battery up and see if problems clear. If not, it probably needs more expert advice than that.
      Does this proceedure lock or render any electronics inoperable after reset? I have heard horror stories.
      Thanks,
      terykely
        No - Absolutely not - The worst thing that may happen is that you might lose your preset radio stations. This is a trick that has always been used since computers were installed on cars - same thing with a home computer - when having unknown problems, just shut down, then, pull plug from wall, wait about 10 minutes, then power back up and you would be surprised how this will correct things.............
          Thanks! I'll give it a try! I really appreciate the help!
            I believe it fixed the door ajar and power lock problem, still sparse skipping at red lights. I'll try to replace fuel filter, cheapest parts first. Can anyone tell me where the fuel filter is located?
              not sure where the fuel filter is located?
              "sparse skipping?"
              the jumping and hesitating on uphills may mean you need to check the c.o.p.s, (coil on plugs) - there are 8 - one or two may have water in them and have shorted out and need replacing.
                Dot, the fuel filter location was checked out by George. It's accessible with the removal of the driver wheel.
                Terry, replacement of the fuel filter is recommended at the 30,000 mi. maintenance.
                Do you have an extended warranty? If the problem is the c.o.p, you're going to need it.
                Redbirdsal
                IRISH THRU & THRU!
                  Sally, did we discuss that fuel filter location over email or the phone?
                    It was on the phone. I was "p---ed" cuz the tech had taken off my driver wheel to change it. During our conversation George looked at one of your Birds, and confirmed the wheel would have to be removed to access the fuel filter.The time frame was right before Hot Springs III, this year.
                    Redbirdsal
                    IRISH THRU & THRU!
                      What is a driver wheel, never heard of it before?
                      Steve & Donalee
                      2004 Merlot
                      When you own a T-Bird, you take the long way home. Runnin' cool on Heavy Duty Fuel
                        The driver wheel is the nut behind the steering wheel.
                          Sorry, what I meant was the front wheel, on the driver's side.
                          Redbirdsal
                          IRISH THRU & THRU!
                            Speaking of which...
                            When is a door not a door?
                            When it's ajar.
                              Wait, so you are saying that unhooking the battery for 15 minutes fixed the door locks?
                              My door locks click when I push the button, but don't unlock. I figured I needed to tear apart the door panels and find and replace the accuater.
                              Might try this first.
