Door Ajar, No power locks, jumpy on hills
    Re: Door Ajar, No power locks, jumpy on hills
    How old is the battery. I had the door lock problem, replaced the battery and problem was fixed.
    Frank
    FEs Tbird
      Disconnecting the battery (usually for 30 minutes) will reset the electronic modules. You may also have a bad module or actuator as you first suggested.
      Good luck and welcome to TBN.
        Don't got tearing any Door Panels apart - Ditto on Battery disconnect or possible replacement (many Threads on this) - 2002 w/54K Miles I say early Cops failing (2002's not immune, I just had that at 47K Miles) but hesitation possibly Voltage related also - Wifey needs to buy you a Code Reader for late Valentines Gift - Fuel Filter is behind Wheel WELL Cover - & Welcome to The Boards.
          I was referring to only to the door lock portion of the problem. If it's both doors, it's most likely not an actuator.
          The first suspect for the hill problem is a bad coil(s).
