Re: Fuel Pumps
Kokomo and MATbird. The fuel pump relay is just a magnetic coil which when energized makes(or breaks) a switch. On most cars the CPU sends out a voltage to the coil of the relay when the engine is running to establish a "holding" circuit and maintain power to the pump AFTER the key goes from start to run position. One indication of a bad relay is that the car starts and then immediatly dies , and will keep right on doing this.A quick fix is to examine other un-needed relays (like a/c) for their diagram on the side of the relay.If its the same and the same part number,you can just switch them and be on your way and pick up a new relay at the auto part store. If you don't want your bird stolen and it must be parked some where for a while (like an airport) you can remove the relay and put it somewhere like the trunk or put a blown fuse in the CPU socket. Car thieves are generally not looking for that. Glad to be part of the forum! Thanks Randy
