Dome light removal
  • Dome light removal
    Dear Sirs,
    I am writing to find out how to remove the hard top dome light. My light has burned out and I need to replace it.
    Thanks for any help.
    Josh
    Re: Dome light removal
    Rock, The dome light is on your windshield header, not your hardtop.
      You will see a seam near the bracket for the Sun Visors. Pull down on each side and the whole header bar should come loose. The bulb are all reachable from the inside of the hearder bar. Afrer you change thebulb, just snap the header back in place. It's really easy.
        there is a instruction on that.. send me a blank email at jyoung@sc.rr.com and I will return it as an attachment... easy to replace bulb ( I JUST PUT IT HERE )
        Jim
        Jim Young
        jyoung@sc.rr.com
        www.jimyo.com
        www.youtube.com/jimyo01
          I have this whole assembly in stock if anyone would like to upgrade there Tbird. It Is a 2005 .Thanks, Rick
            What benefit would it be for me if I upgrade my 02 assembly?
            HKLS
              benefit - garage door opener if you have an automatic garage door.
                Dot, isnt the lighting a little better on the interiors of the 05 VS 02?
                  Dot,
                  Have you done this to your 02? Do you know who has one in an 02? Is it just plug an play or do you need to modify wiring? If it is plug and play, then I will get one.
                    Here's how:
                    http://www.thunderbirdnest.com/forum...light=Homelink
                    Ski
                    nomorebirds
                      Please send me a private e-mail with the price and description. I plan to put it into my 02 blue.
                        Hi! I was up gradeing the map light bulbs in my dome light assembly on my 2005 and now the whole thing won't come on. It will sometimes, but not often. Is it the fuse? I checked all the fuses and they seem good. Tried a bunch of different bulbs. No luck. Does anybody know where I can buy the entire dome light assembly for my 2005 Bird? Thank you!
                          You probably don't need a new assembly, it's probably a broken wire or loose connector. Take an ohm meter and test the voltage at the bulb clips, then the connector. It's most likely a problem where you were working on it.
                            Thanks for the post as I need to replace my dome light in my "05". Sure don't want to break or crack anything?? Do clips hold it that I need to watch out for?? Thanks again. Bob
                              mttop
