The brake light has been intermittently on and off for about 2 weeks (as I was driving). Lately, the on time has been nearly all the time. However, it is temperature sensitive -- on when air temperature cold, off when it warmed up to about 70. I wasn't too worried since I had had a similar problem on my Jeep once and that turned out the the problem was the switch on the hand brake. However, the brake light on the Tbird is more scientific--it also senses if something is going wrong with your brakes. Took it in for a check and found that there was leak in one of the rear calipers. Yikes! So FESTBRD is resting at Sunnyvale Ford tonight, waiting for the parts to come.
Intermittant Brake Light
Re: Intermittant Brake Light
Originally posted by Ediron View PostHad the brake light go on in my Pontiac GTP yep it need rear shoes.Four pair of front to one rear.
Jamessigpic
Just a catch up. After the rear caliper was fixed, they decided the brake peddle was too mushy--soooo, they are putting in a new master cylinder. This time they reminded me that the extended warranty policy allows for a rental. Hope they can get the part, fix the car and get it back to me tomorrow. Too much to do this weekend to be worrying it.Frank
FEs Tbird
James the GTP had disc all around.I went through so many sets of front breaks I can't count.If you got 8K-10K on them you were lucky.One of the main reasons I traded it in as side from being a snow plow in N.Y.The spoiler was only 3" above the ground and when it snow you just didn't use it.Bought a new Bronco in 96 more practical for me.
P.S. Gm had a class action against them for the brakes .I received the notice in 2000 and you need all you bills.Last edited by Ediron; Mar 27, 2009, 09:43 AM.sigpic
