One of our Members of the Las Vegas Thunderbirds did a Mod to his car about a month ago to carry a full sized wire wheel spare wheel & tire. I've waited as I thought he would post pictures, but he hasn't, so I will. He removed the carpeted fiberboard floor and had a piece of smoked plexiglass cut to shape. Set in his spare wheel & tire and laid down the plexiglass. He put a Ford oval decal at the farthest point forwad on the plexiglass. The wheel & tire & battery are all beautifully visable. I have 3 pictures as it was impossible to get a shot without glare in the parking lot we were in.
Full Sized Spare
Re: Full Sized Spare
Originally posted by MintTbird View Posthow does that full size fitLimited Edition databases for 007 msg..#26 , PCR sticky, and Cashmere msg.#64
That just screams cool!
Like Dot said, the opening is big enough. The problem comes with the recessed shape of the factory trunk floor that makes for a little more trunk space. There was a similar post some while back, where a cut piece of plywood covered with the original type gray material was used to allow a full size spare to be installed.
Jamessigpic
Originally posted by Ski View PostBut don't you lose performance by removing the trunk mat?
Thanks, John for your insight on this important piece of hardware.
Jamessigpic
OHHHH I do like this MOD. I hate the small spare tires. I wonder if the 2 Pc Hard tonneau would fit better also or would I loose space ?1 Of 1938 Made
This car began life as a Ford Executive Lease Vehicle
TO all TBN members I replaced my donut with full sized tire and matching rim. Had to reposition Jack and without changing trunk tire cover, it sticks up about 1 1/2 inches and does not make a clean flat floor. This new way to do it seems great. However I have had this spare in the trunk since 2/03 when I got the Bird and have never needed the spare and wonder if it was worth the cost. I do have the security that I do have a "regular tire" if and when I need it.
On my 2005, I just left the donut in and we use that for more space needed travel.
Thanks
Dennis
