Airbag - "Too Much Resistance"
  • Airbag - "Too Much Resistance"
    I recently had my airbag light come on my 2002 Thunderbird. I took it to the dealership and they said it was the clockspring. I really didn't believe them because they seemed pretty shady. I took it to my local mechanic and he said that the airbag had too much resistance and it was a wiring issue due to the design. He said I should take my car to the dealership and they should replace the airbag for me free of charge. Has anyone come across this issue? Any suggestions? What should my approach be?
    Thank you so much!
    Re: Airbag - "Too Much Resistance"
    Yes, I have a similar issue in my 2003. Flashing airbag light now and then. (More now, than then). It more than likely is a poor connector/contact (Either in the clock spring or the seat connectors underneath the seats). You could try to see if there is an airbag fuse, and check to see if that fuse is corroded or not making a good contact.
      Mine is flashing and/or on solid now. I'm taking mine to the dealer next week to find out what's going on. If the light is on, they won't deploy in an accident. NOT good.
        Replacing the clockspring did fix this problem for me on the 2002 last year. I replaced the clockspring because of the horn (for inspection). About a week later, the airbag light quit coming on.
        ~Jimmy
          from past discussions, in which kokomo was part of, the clockspring has been the first culprit to check out when having an air bag light come on for no apparent reason. changing the clockspring seems to have fixed most that have reported the problem.
            What is a clockspring, where is it, and what does it do ?
              start with this thread:
              http://www.thunderbirdnest.com/forum...ht=clockspring
              it's in the steering column and allows the steering wheel to turn
              you might also do a search on clockspring and airbag light
                I believe it's what maintains electrical contact as the steering wheel turns without constantly twisting & stretching wires.
                  Clockspring for the win. Not all that hard to change.
                  My Current ride is a 2011 SRT Challenger
                  Failure is the opportunity to begin again, more intelligently.
                  Henry Ford
                    It's not the clockspring. My mechanic checked it and it was fine. It's the airbag itself, it's defective and has too much resistance.
                      How many miles do you have on your car?
                      ~Jimmy
                        I have 42,000 miles on the car.
                          The driver's airbag module has an incredibly small and fragile electrical connection - looks like something you would find inside your laptop computer.
                          If I was getting an airbar light I would try removing the module and "DELICATELY" CLEANING the connection (locking type, gently squeeze and pull). It's an easy 15 minute job - detailed instructions for accessing the module can be found in a steering wheel removal thread.
                          This might not help - it may well be a clock spring problem or something else. However, I think it's worth checking out.
                          CAUTION!!! You MUST disconnect the battery before accessing the airbag module.
                          Tom
                          sigpicRIDGE TOP PERCH FOR A THUNDERBIRD
                            Austx
                            Thanks for the advice. I am terrified of taking on the task on my own! I guess what I am so confused about is why does my mechanic think it's not the clockspring and why doesn't he try to repair it if it was something else?
                            I don't want to spend $450 (what I was quoted for at the dealership for replacing the clockspring) if that is not the issue.
                              The reason I asked about mileage is that my 2002 started having airbag light issues at about 50K. Also, I doubt that the dealership will replace your airbag for free without first trying the clockspring.
                              ~Jimmy
