Hi, The S type is from the Dew 98 Platform like our Birds, Battery is fully charged all the lights and locks work fine but when you turn the key it won;t even turn over. Any Suggestions from the Mechs out there? Thanks for your Time, Rick
S Type Jaguar Will Not Start
Re: S Type Jaguar Will Not Start
Rick, do you have both sets of keys for the car? Have you tried the other key? You'll have to wait abit though to try with the other key to allow time for the lock to reset.
If that doesn't work then you'll need to dig further for the problem.Limited Edition databases for 007 msg..#26 , PCR sticky, and Cashmere msg.#64
Rick,
Like Bruce said, it could be the neutral safety switch. Can you pull the gearshift lever out of "park" into "neutral" and try to start it there? If that doesn't work and you have the owners manual look and see if there is a procedure in it for "Gear-shift Interlock Manual Overide". You have to remove the screw-in plug to do this that is located on the gearshift facia above the "park" position. You either insert the igintion key or similar tool into the hole and push down GENTLY while simultaneously moving the selector put of "park" and into "neutral". Then see if you can start the car after removing the tool. Make sure you are on level ground, have the wheels chocked, and emergency brake on.
Dot's suggestion to try the other key is a good first step.Last edited by V8 Cat; Jul 19, 2009, 05:51 PM.sigpic
2010 Jaguar XK coupe
1985 Honda Nighhawk "S"
2013 Lexus RX350 - wife's
2013 Mercedes E-350 coupe
This happened to my Lincoln LS.
If you turn the key on and she still will not come out of Park or start, try rocking the car slightly. Also, try moving the steering wheel. (My dealer says this sometimes works.)
I had my car towed to the dealer, and it started there first shot. Just the movement during the tow must have done something.2010 Explorer Limited Edition, tri color white, camel interior
