need tips
  • need tips
    I'm putting my 02 T-Bird to bed for the winter, anyone have any advice for winter storage, like hardtop on and soft top down ? Battery taken out? any other tips?
    Dan
    Re: need tips
    Here you go Dan:
    http://www.thunderbirdnest.com/forums/showthread.php?t=7432&highlight=winterizing
    If you want to use the Search function on the dark blue tool bar above, you can enter "winter storage" , or just "winterizing."
    You'd be hard pressed to find a topic that hasn't been discussed here over the years.
    Redbirdsal
    IRISH THRU & THRU!
      Re: need tips
      I put the hard top on for the winter and install the cover. I go in about the first of every month, remove the cover, start her up and let it come up to temprature. I then drive her around the garage, under ground parking lot, a few times then park it and cover it back up. Never have removed the battery.
      Ted
        Re: need tips
        Full tank of gas and don't use any additives like Stable in your gas, they contain alcohol and will ruin the seals in your fuel pumps. Use a battery tender if possible, otherwise don't arm the alarm, it will drain the battery. If possible start the car occasionally and let it run till warmed up. I keep my car covered with a fitted cover and garaged and try not to open the door if there has been a drastic increase in temperature and humidity outside as it will cause the car to sweat. First thing in the Spring I take it in for new oil and filter, battery check and check and rotate the tires. I've been doing it this way for four years with no problems. Leroy
        \ \ \ \ \_______________________________________
          Re: need tips
          Leroy,
          I just looked at my bottle of Stay-bil and it says, Does not contain alcohol. Also I don't know where you get your gas, but here in Maryland almost all gas sold contains 10% ethanol. Probably is a good idea not to put in any additives containing more alcohol into gas which already has it in it, which may cause some problems. Hopefully the 10% ethanol gas will not destroy our fuel pumps or anything else in our TBirds.
          Bob B.
            Re: need tips
            By spring the ethanol would have probably evaporated.
            I've used Stabil for many years in boats, compete with carburetors and rubber fuel lines etc and never had a lick of trouble.
            The idea is not to put it into the gas tank and walk away.......run the car a few miles. Get the Stabil well mixed and distributed around the delivery system....in the fuel pump.. in the lines etc.......
              Re: need tips
              Move to Florida use the Bird year round and forget about all the above
                Re: need tips
                I've used Stabil for over 40 years and never had a problem
                  Re: need tips
                  Good suggestion, but not state specific. There are always days that you just need a good T-Bird run. Nothing better for you than a top down jaunt on a crisp, sunny day. I hate to even put the hard top on, but that's another story.
                    Re: need tips
                    Amen Bro' and yes it's ethanol that's the killer not Stabil. Leaving battery in is essential and I would use a battery tender. But leaving a Bird sit for 4-6 months is just nothing but cruelty. Almost as bad as driving on salt YUK And people actually choose to live in the north???
                      Re: need tips
                      i live on the snowy side of washington state...i put the 04 away with a full tank of gas.....once a month i back it out of the garage,let it warm up....if the streets are clear enough i drive it around the block a few times...if not i back and forth it in the drive way....cars need to be ran...
                        Re: need tips
                        You are absolutely correct Ron, about gas stabilizer, as it has no alcohol in it. Matter of fact is has, on the plus side, a chemical that reduces and/or prevents the corrosion that condensation (water) and alcohol can and does create The alcohol in the gas is what creates corrosion and softening of rubber seals.
                          Re: need tips
                          The following is my list
                          Items to Do
                          Thunderbird
                          Bounce towels throughout & under hood
                          Charcoal briquets in pan throughout
                          Place towel under wiper blades
                          Lower windows 1-2 inches prox.
                          Remove mats
                          Add Stabil & fill tank w/ gas. 1oz/2.5 gal (7oz/full)
                          Wash and Cover
                          Plug in battery tender and add paper mat w/note
                          2 Desicants inside car, 1 in trunk.
                          Add odorizer
                          Lockout garage door at button and bar on door
                          Run car with A/C off, vent blower high
                          This is what I do when I store my car for the summer.
                          Last edited by keithwand; Oct 28, 2010, 09:28 AM. Reason: did not come out as spreadsheet
                            Re: need tips
                            Oh well that did not come out as planned. I tried to copy and paste a spreadsheet but you get the idea.
                              Re: need tips
                              Up here, we use our cars in the summer.
                              Also, you seem to be hung up on the odor factor - have you ever thought about just giving up burritos?
