Brake Caliper Covers
  • Brake Caliper Covers
    Has anyone looked into or tried the new brake caliper covers by MGP that Aaron is offering on his site? I painted mine black (a pain) but they don't really show well, red or silver might look better for the black bird.
    gary
    Re: Brake Caliper Covers
    Do you have pictures?
      I got a Red set for Christmas from Jeannie. I'll put them on this week and post pictures. They should look GREAT!
        David,
        Are your covers from Aaron or are they Ford's Official merchandise? Aaron's have a series of faux hex heads arched around the edge. The official Ford merchandise shown in this thread are void of the hex heads. (see two versions below)
        __________________
          Diana got me a set of the red ones from Aron and they don't have the hex heads marked on them at all. I'm hoping to install them sometime in the next two weeks.
          _______________________________________
          TBN Badge and Lots of "TLC"
            I don't understand why Aaron would picture a design that he is not offering. There is a dramatic difference between the two offerings.
            but I have found the hex model at http://www.carid.com/2003-ford-thund...gp-104052.html for $189.
              Mine are without the hex head. Interesting that the hex head set are labeled 2003. Is there something different from 2002? frankly, I like the plame ones better ... the hex head set looks too "busy".
                David,
                Are your covers made from aluminum or are they a composite of some sort? I checked the site with hex head designs and they will fit 02-05.
                  OK, here are pictures of the installation of my covers.
                  This is the rear. The clips just slide ofer the calipers and then the covers go on. Tighten down the nut and it's done. Take about 5 minutes per wheel.
                    The fronts are just as easy.
                      Here they are done. I think they really dress up the wheel and much easier than painting.
                        BTW, it cost me $5.00 per wheel to have it done. I checked the tie-rods and rear-end and found that I need a right side tie-rod and some rear bushings. I had a little shake in the steering and found that right side problem. The car has 95000 miles on it.
                          Here's a "before" look. Brakes are ceramic and show almost no wear in about 50,000 miles. Slotted rotors are near perfect as well.
                            They look good on a black car. I think the only color that would go with the blue would be the silver ones.
                              Very Nice, David. I plan to have mine installed Thursday.
