For the DIY people Out There
This is a sticky topic.
  • For the DIY people Out There
    There is a wealth of information here on TBN for the people that can do things yourself. Some of it is simple and some is more involved. It's up to what skill set you may have but can save you big bucks compaired to going to a dealer.
    On the bottom of this page in the link you can click on and go from the beginning to see all the postings on this subjact.
    http://www.thunderbirdnest.com/forum...play.php?f=151
    Re: For the DIY people Out There
    Thanks Spence,that's a wealth if information in one place.
      Wow, that took a lot of work. Thanks Spence
      WHATS THE WORD? THUNDERBIRD !!!
      9 of 612
        Many of the members have posted to this section of TBN and that's what makes TBN the place for the Retro Bird.
          Just added to my reading list!
          Thank you,
          David
            Spence
            THANKS
              Probably a lot of duplication, but here's more.
              http://www.thunderbirdnest.com/forum...splay.php?f=83
              and more,
              http://www.thunderbirdnest.com/forum...splay.php?f=84
                Great reference and much appreciated.
                Thanks
                  Thank you Spence, I booked mark this page for future reference work on our T-bird...
                  Dennis
                    Dennis
                    I did the same along with sixpac's additions fast handy reference.
                      You rock, Spence. This is going to save a lot of us a lot of clicks and head-scratching -- not to mention $$$. Much appreciated. -- Bob
                        Spence,
                        This one could be an added value if you would like to remove your CD radio. I used it to
                        remove it and fix it on my own.
                        http://www.youtube.com/watch?v=jWxwnf2gCpM
                        Alain
                        Alain
                          changing antifreeze in 2002 bird
                            What a great resource that link of DYI threads is, thank you Gobird.
                              Hi fellow Birders. I have had my 2004 black bird since 2006, and love the car. I had two Lincoln LS's before that, so knew it would be a great car. I have had no problems except the COP situation which many have experienced. (I had the same problem with both Lincolns) I was fortuniate in that Ford replaced all 8 of the COP's under warrenty.
                              I have a new problem now, and hope that some of you can help. I finally had to replace the original battery in the Bird. I bought a new battery from my Ford dealer, and replaced it, with minor skinned knuckles, and very little cursing! The problem: you know how when you open the door, the window drops about a half inch to let the door open, and then goes back up when you close the door, in order to make a tight seal. well, all was working fine until I replaced the battery. After reconnecting the battery, the window drops, when opening the door, but then won't go back up when the door is closed. Any help would be appreciated, Thanks.
