Correct, it ain’t gonna make it. You need a 50 series spare. I’m not concerned about the small diameter difference to the 55s on the car as it will only be used briefly if ever. Would have the same difference with the Maxxis. From now on I’ll be buying all 50 series.
Spare Tire Replacement Question
I took the bird to the tire dealer. He is suggesting putting a full size radial boat trailer tire on the spare's rim that would be the same diameter and height as the compact spare. The trailer tire runs at 32psi instead of the 60 psi of the compact and cost about $75.00. Since reading the reply here, I am going to contact Maxxis before deciding. I think I like the idea to keep it stock if a OEM tire is available. Thoughts about the trailer tire idea?
Originally posted by vinnie View PostCall this lady at Maxxix Canada, she'll take care of you. Jessie 905-789-0882 ext 214.
BobRDRIDER
Tri-Cities, WA
Originally posted by IdahoBob View Post
Thanks for this contact! I called her and our new spare is on the way! Is there a market for a brand new, never on the ground, 15 year old Maxxis spare tire?
Bob
Part of my job is checking spare tire pressure and I can guarantee you that none of the 1-5 year old cars has 60 psi in them. We do pump them back up to 60. I'm not anal about it in my own car. Some people here appear to be way too anal.
Originally posted by 04TBIRDNOLast night my spare tire "blew up" and caused the trunk to lift up. Now I cant get the trunk to close. It seems like the latch assembly is broke. Note: It also destroyed the fuse box assembly in the trunk. Any help will be greatly appreciated.
