Check engine light AGAIN / code p0108
  • Check engine light AGAIN / code p0108
    Car runs fine , starting ok , no hesitation , no smoke , idle is normal . Any pointers welcome
    P108 is a very common code and often times only requires you reset the code.
    If that doesn't work change the MAP Air Sensor. It is a fairly easy procedure and not very expensive.
      MAP was cleaned and the engine light went off , thinking that the EGR valve needs to be replace ?
        FYI. I took my 03 t bird to a local shop. I checked my gas cap after everything checked out. The mechanic took a rag and wiped the rubber gasket around the gas cap thoroughly and no problems since. Try it. Good luck.
          thanks for the tip
