Is an automated car wash a good/bad idea for the hardtop?
Car Pool Car Wash
Re: Car Pool Car Wash
You may find some leaks you never knew you had, but it shouldn't hurt the finish anymore than the hood or trunk.2010 Explorer Limited Edition, tri color white, camel interior
If its on the car you should be ok, but don't try carrying it through or rolling it on the storage rack. Only took me once to learn that was a mistake....Bird is the word.....
I also found when I removed the HT at the end of winter, start of Spring, the soft top had water marks from where I think the pressurized water spray got into the soft top from under the HT seal. At least I think that is where or how those water marks got there. Really don't know.Mike
- May 2005
- 3478
- Elle & Charley
- Norfolk,Va/Islamorada,Fl
- -SELECT-
- Send PM
Did I say that enough?sigpic
Drive like you mean it!!
~Elle~
Originally posted by steelblue5505 View PostI also found when I removed the HT at the end of winter, start of Spring, the soft top had water marks from where I think the pressurized water spray got into the soft top from under the HT seal. At least I think that is where or how those water marks got there. Really don't know.sigpic
“THE EDGE,there is no honest way to explain itbecause the only people who really know where it isare the ones who have gone over.”
If you fill up with gas and get a free car wash, don't forget to put your gas cap back on. We had a member from California at Thunder Fever (?) who forgot. He went thru the free car wash with gas door open and no gas cap on. No damage done. He lucked out.
It's not a problem, my car has been through numerous automatic car washes with the hardtop on it. If it's installed properly, you may only get a slight drip in the front corner[s].PK- 2002 Premium Blue/Full Accent/Whisper White TopVIN#16336
Built April 22, 2002
Purchased July 24, 2002
Just took mine through the hand held one this Morning to knock the dust off.
@ Rusty I'm glad I've seen some of your post before, I laughed the whole time as I was reading the rest of the post. I can just picture that now someone carrying or rolling a top through a automatic car was. I don't suppose you got that on video.2004 PCR 253/1000 The wife's car (I let her think this)
Mine has been through a couple of these over the past 10 years without any problem. I won't take it in one now because of the trunk rack I have on it now.They are Here. Scotty, beam me up!IT'S 5 O'CLOCK SOMEWHEREVisit the TBN Store
Is anyone concerned about a carwash causing a problem with your coils or plugs? I think I've read on here about someone going through a carwash and immediately having symptoms of a coil going out. Am I being overly concerned? I just had all 8 replaced, and I don't want to risk having another cops problem.
Originally posted by EpTxGuy View PostIs anyone concerned about a carwash causing a problem with your coils or plugs? I think I've read on here about someone going through a carwash and immediately having symptoms of a coil going out. Am I being overly concerned? I just had all 8 replaced, and I don't want to risk having another cops problem.They are Here. Scotty, beam me up!IT'S 5 O'CLOCK SOMEWHEREVisit the TBN Store
